10-19-2014 02:41 PM
As I said, the most difficult time I had was in removing and replacing the plastic floor plate, John in his video used a plastic knife, tends to cause less scratching, gouging, I used a small screwdriver. Although I didn't scratch or damage the plastic, I'll remember to keep a disposable knife handy for that purpose.
Thank John in Cozumel for his video.
Jim
10-29-2014 02:54 AM
12-09-2014 08:36 AM
I was so hopeful when I saw this. I had realised there was something rattling around inside my camera when both of my batteries stopped being recognised.
Followed the instructions, found and returned the loose screw to its rightful home....
(that bottom plate is tricky to get back on the camera !)
But no luck, same response from both batteries.
I will be examining the board (etc) again one evening and I might try a battery in or from another camera...
Keep trying.....
12-15-2014 02:24 AM
@Zathrum wrote:I was so hopeful when I saw this. I had realised there was something rattling around inside my camera when both of my batteries stopped being recognised.
Keep trying.....
Unfortunately, since you heard the screw bouncing around inside, it may have shorted between some traces and may have caused attitional damage. I'm assuming that you completely rebooted the camera, removed the main battery and the coin cell. When you did that, you had to reset the time, etc, as it would bring the camera back to factory defaults.
Canon is very good at selling repair parts, if you don't know the part numbers, they are very helpful. I don't have a diagram of the camera but believe the bottom board is the power supply board. I'd hate to see you buy circuit boards until the problem is solved. I was unable to find a service manual on the camera but did find a parts manual, don't have a link for it at the moment.
Good luck with it - Jim
12-15-2014 04:54 PM
12-21-2014 11:07 AM
A new developement to this issue I've lived with for 1.5 years by taking the battery out every time I'm done with it so it doesn't drain over night. A little background: I bought the 7D used with two batteries included that looked to be original Canon, and everything worked as it should 2011-2012. Right before a vacation I forgot one of the batteries and the charger on the ship I work on, and replaced them with new Canon products. I noticed the battery looked very similar to the ones I had, but included a silver stamp area on the back with the year/month stamped into it (not pressent on the first two). As soon as I used this new battery (and if I rememeber correctly a firmware update) I lost communication with all 3 batteries. It was frustrating but couldn't bring myself to spend the $300+.
Strange thing happened today, I just bought a 7DII and while charging the included battery I popped in one of my old ones to play with settings - same error message! I took out the battery and it was one without the date stamped. I replaced it with the one I bought in 2012 that had the stamp, and it works fine. It also still shows three green bars for condition so I'm happy with that.
This still doesn't explain why this new battery seems to have triggered the problem on the 7D, and why all 3 batteries were affected. I dodn't know if the original 2 batteries were 3rd party made to look like Canon, or if the date stamp was a new addition later in production.
Well, the 7D has a buyer and the battery read issue was disclosed - told him I'd throw in a second battery. Guess I know which 2 batteries I'll be including.
12-21-2014 05:58 PM
12-25-2014 05:39 PM
03-25-2015 09:11 AM
Just thought I'd add that I had the battery board replaced and camera cleaned. It feels like new and works the way it ought. Though a bit of a wallflower now that the 7D2 is my favourite new toy. Am loving the AF system.
12-22-2015 07:39 AM
I had the same problem and brought my 7D to Canon.
I had to pay USD 95 and they replaced the DC current with the new one.
It is solved now and no problem at all although I am keeping the battery inside all time.
