01-20-2021 12:19 PM
I have a Canon 7D Mark II and a Macbook running MacOS 10.15.7 running the 1.1 release of the EOS Webcam Utility. I have the camera setup as a webcam and works great except for one new behavior. If I'm in a meeting longer than 30 minutes, it'll shutoff almost exactly at 30 minutes for a couple seconds and then reconnect. It sounds like it is power cycling. In the Setting menu I already adjusted the Auto Power Off to disabled. When I had the beta webcam utility, this wasn't happening. Only really started noticing it after I updated it to 1.1.
Any thoughts on how to fix this?
02-08-2021 03:45 PM
Glad to hear that this worked for you too!
02-08-2021 05:20 PM
02-13-2021 11:18 AM
04-21-2021 12:30 PM
Just came here to say, your solution works on my Canon T2i and thank you, you a true internet hero.
05-04-2021 08:02 AM
05-04-2021 08:24 AM
11-22-2022 09:26 AM - edited 11-22-2022 09:27 AM
@bridgewrote:
Great question. I don’t have any idea why it worked. I guess I just got lucky.
If I had to venture a guess as to why it worked, then it would be because the default setting is not disabled. One minute might be the default, I’m not sure.
It is a safe bet that the Webcam Utility has to make a number of assumptions about camera settings. The best assumptions to make would be settings are at their factory defaults. The same app seems to be used with a wide variety of cameras, each with their own set of menus and options.
11-22-2022 11:45 AM
But how do you stop the screen displaying that no card is inserted?
Do you guys use video mode or AV, M etc.
11-22-2022 11:46 AM
Very basic question. Does AV mode work for webcam use, if so how do i do this?
11-22-2022 09:31 PM
I tried this last week and seemed to work. Now with auto power off set to 1 min, the camera shuts off in 1 min. What am I missing here?
