11-10-2018 10:26 PM
I got this cnon t6i and evertime I take pictires it says buisy even when I change memeory card, tried using different card ans resseting, but video works ok.
11-11-2018 02:34 AM
@buckjamesmd wrote:I got this cnon t6i and evertime I take pictires it says buisy even when I change memeory card, tried using different card ans resseting, but video works ok.
Does it let you take a picture, and then display “busy” for an extended time?
Do you “low level format” your memory cards in the camera prior to first use?
What is the brand and model of the memory card you use, and is it a micro-SD card or a regular full size card?
11-11-2018 09:23 AM
Did you turn on some setting that requires a lot of processing, like HDR? You might try resetting the camera, taking the camera outside on a sunny day and use green-square mode to take some pictures. Does it still happen?
11-11-2018 09:53 AM
11-11-2018 07:27 PM
Longshot ideas, first try a reset to defaults if not then try taking out the battery and holding down the power on button for at least 30 seconds then replace the battery and try again.
11-11-2018 07:08 PM
Hello buckjamesmd,
It sounds as though there is an internal issue with the unit which should be evaluated at the closest Canon factory service center.
You may fill out an online repair request form at the following link to setup your repair using our online service.
https://www.usa.canon.com/internet/portal/us/home/support/service-repair
