06-22-2014 03:22 AM
Twice now I pulled my T3I out of my camera bag turned it on and the battery was dead. The first time I thought I might of left it on but this time I know for a fact that is was off. I have version 1.0.2 the camera is new I got it may 22 2014. from costco. I did get a new memory card scandisk extreme 32gb 80 mb/s but it was not in the camera this time. Im not sure if it was in the camera the first time Im not even sure if I had the memory card when I first saw this problem. The batteries are real canon batteries they came with the camera I also have the 18-55mm lens that came with the camera this is the lens that was on the camera when this problem showed up.
05-29-2015 06:06 AM
Hi there, I'm having the same problem. Did you fix the issue, or did you send yours back to Canon?
05-30-2015 01:47 PM - edited 05-30-2015 01:48 PM
As said before, things that can make your battery to drain:
I had battery drain on my 1000D. A new firmware helped me.
06-01-2015 08:16 PM
06-02-2015 03:04 PM
Ok. Thanks. I'll try that
