12-26-2023 09:54 PM
Recently purchased newest version of Atomos Ninja V and own a Canon R3. Having difficulty figuring out the right camera / monitor settings to get R3 to record to Ninja only. Currently I can only record to card slots in the camera body. Using HDMI out of camera to HDMI in on Ninja. I am able to get camera menu to show on Ninja. I suspect that there is a setting or multiple settings that I have messed up. #R3, #Ninja V, #Ninja 5, #External recorder
12-26-2023 11:08 PM - edited 12-26-2023 11:08 PM
See page 421 in the User Guide:
Deactivate in camera on screen display. Then use the INFO button and ensure no shooting into is being displayed in the camera. You will use the external recorder.
12-27-2023 12:56 PM
Thank you for the prompt response. I did go back to the manual and read up some more. After following the instructions outlined by yourself and the manual, I have determined that this did not get the desired result. All of the display was on the monitor only but was unable to get any files to record other than to the cards in camera. It is possible the issue lies in the monitor setup and am waiting on response from that end.
02-22-2024 02:38 AM
I too am having issues. I'm starting to wonder if it's to do with my monitors. I have both Ninja V and Shogun7 and I can't get either to record RAW on my R3. The record bottom is greyed out.
Did Atomos get back to you about potential issues on their side?
02-24-2024 08:29 AM
04-07-2024 10:44 AM
Hi i am having the same issue, I can get the R3 menus on the Ninja with some settings and occasionally the video flashes on and off. How did you resolve this issue in the end ?
04-07-2024 12:26 PM
Im not entirely sure what I did to resolve this. The last thing I did was to do a factory reset on the Ninja and that seemed to work. I did have it stop once again after that and managed to get it working once again not really knowing what I did to make it happen. My personal feeling is that there are certain combinations of settings in both devices that will allow/disallow proper operation. I have not been able to trigger recording from the camera. I have to touch the record button on the ninja to start recording. Im still learning the configuration of both devices.
