12-04-2012 11:29 AM
I am ready to scream!!! I have changed the file size to "L" but resolution is still 72dpi!! no matter what I change, resolution size will not change.
12-04-2012 12:11 PM
You (& a lot of people before you) are confusing DPI & pixels thanks to your editing program. Take a look at how big it says your image is on the top & side rulers. That is how big it would be IF printed at 72 DPI. It has nothing to do with the camera settings you think you need to change. Large Fine is the highest resolution, makes the largest file & gives the highest quality large print, but we don't print at 72 DPI. Usually 300 DPI & more are used & although I can't specifically tell you how to re set the software to a number in the 300's it's unimportant. The printer will use the best DPI it can for the size of print chosen assuming you haven't set it up differently (not a common practice).
