08-12-2018 05:50 PM
I have what I suppose to be a first gen 1.4x TC that I use with my 600mm f4 lens.
I am thinking of buying the 7D2 and the current 100-400 is II as well. Would the old TC work with that,
or would the new electronics require the newest gen 1.4?
It is hard to have to replace everything! (I am sure many of you have gone through this).
Mitch
08-13-2018 08:38 PM
@mitchmcc wrote:
7D2 + 1.4 (iii) + 100-400 II (or substitute the 80D for the 7D2)
I greatly appreciate everyone's help, as I want to put in my order pretty soon.
Mitch
I have already put in my two cents. Make your own choice, based on your own priorities and needs, not the preferences of someone else.
With the 7D2 + 1.4XIII + 100-400mm II = One AF point, the center AF point.
With the 80D + 1.4XIII + 100-400mm II = 27 AF points, three rows of 9 AF points.
The choice is a tough one. Each body had distinct advantages over the other. Hands down, the 7D2 has a better build and body. It has a slightly higher frame rate, which is meaningless with a slow lens, or a slower AF system at f/8.
On the other hand, the 80D has higher resolution, lower ISO noise, and better AF tracking [higher keeps rate, IMHO] due to a better AF sensor.
08-14-2018 10:02 AM
"That gives an f8 at at least 560mm, ..."
I shoot my Sigma 150-600mm f/5-6.3 DG OS HSM Sports Lens at f8 all the time.
EOS 1DX @ 600mm, f8, 1/1250 SS. 1600 ISO
I hand hold almost all my bird shots but 560mm on a 7D Mk II with its crop advantage is goin gto be a real challenge to hold still at nearly 900mm. Of course I would give it a go!
08-14-2018 10:11 AM
I am used to using a tripod 100% of the time, so I would probably try that using the 1.4....
08-14-2018 10:22 AM
@ebiggs1 wrote:"That gives an f8 at at least 560mm, ..."
@EOS 1DX @ 600mm, f8, 1/1250 SS. 1600 ISO
I hand hold almost all my bird shots but 560mm on a 7D Mk II with its crop advantage is going to be a real challenge to hold still at nearly 900mm. Of course I would give it a go!
Interestingly, if you get out a magnifying glass, that picture is sharper than it looks. I guess it's one of the few instances where a blurry background doesn't really serve its intended purpose.
08-14-2018 10:45 AM
" I guess it's one of the few instances where a blurry background doesn't really serve its intended purpose."
Although I have no idea what you are trying to say, the shot simply shows a Great Blue Heron perched in a tree! A quick snapshot I took while fishing at Pomona Lake.
Yes, I carry my 1DX and big Siggy plus all my fishing gear at the same time. Doesn't everybody?
08-14-2018 08:09 PM
@mitchmcc wrote:I am used to using a tripod 100% of the time, so I would probably try that using the 1.4....
Unless you’re set up and not plan to move, then a monopod with a good tilt head works better for action photography when you’re on the move. Most professional sports photographers seem to use them.
BUT, a monopod/tripod can slow you down when you need a quick shot, or if you need to angle the camera upwards. Frequently, I will retract the monopod leg, and go “handheld”.
It is a trade-off. I have captured my best shots by parking myself somewhere and waiting for the wildlife to come out of hiding.
08-15-2018 06:46 AM
"parking and waiting" is how I get my best shots at Ft DeSoto Park near where I live...
https://www.flickr.com/photos/21063695@N05/albums/72157629529792860
08-15-2018 01:39 PM
JMHO, back off on the slidders in your post editor.
08-15-2018 01:42 PM
I do not know what you mean "adjust sliders in post editor"...
08-15-2018 02:16 PM
It is usually a 'less is more' thing. Don't go overboard.
