06-03-2018 04:35 AM
hi can anyone please tell me how to activate the built inb pop up flash to change from ttl to manual flash
thank you!!
06-03-2018 05:42 AM
@lukeyb1234 wrote:hi can anyone please tell me how to activate the built inb pop up flash to change from ttl to manual flash
thank you!!
Hmm, check the instruction manual. Most Rebels have a button with a lightning bolt icon on it, which is located on the top surface, near the main wheel. The SL2 seems to lack such a button.
You should be able to release it through the Quick Menu screen, but the SL2 seems to lack a [Q] button, too, but the functionality seems to be repurposed within the [SET] button..
06-04-2018 12:06 PM
"...to change from ttl to manual flash"
A far better idea would be to buy a real external flash. The Canon Speedlite 430EX III-RT woul dbe a nice unit on a SL2. The built-in flash is almost useless. IMHO, of course.
06-04-2018 04:12 PM
Hi lukeyb1234,
The built-in flash of the Rebel SL2 is fixed on the ETTL-II flash mode. When using the built-in flash only the Shutter Synchronization and Flash Exposure Compensation settings can be changed.
When shooting with an external Speedlite you can select the flash mode to better suit a given situation (ETTL, Manual, Multi-flash, etc...). This information can be found on pages 192 and 193 of the camera's manual HERE.
If you have further questions about the flash operations of your SL2 I recommend contacting our Technical Support HERE.
06-04-2018 08:43 PM - edited 06-04-2018 08:44 PM
@ebiggs1 wrote:"...to change from ttl to manual flash"
One problem with built-in flash that rarely gets mentioned is that Ernie's (and my) favorite EF-S walkaround lens, the 17-55mm f/2.8 IS, casts a huge shadow in the flash's coverage area, even on a 7D. I learned that the hard way on an important shoot. (Fortunately, all I lost were pictures I took of the hall's decorations before an event began; I was using the built-in only to save the batteries on my 580EX.)
06-11-2018 04:02 AM
I know I could just buy an external flash but I don’t have the cash I am only 12
06-11-2018 04:02 AM
06-11-2018 07:46 AM
Did you look for a button with a lightning bolt on it? I thought the SL2 did not have one, but they hid well.
