02-19-2016 01:29 PM
i have a canon rebel t3i and the flash seems to be out of sync.. it fires, but the photos are still dark.. not sure if its firing too early or late. but i wonder if i changed a setting that does this.. need help to fix.. if nothing else, maybe a factory reset.. tho my menu doesn;t have the clear setting mode.
any help ?? thanks
02-19-2016 01:33 PM
Do you mean the built-in flash?
Does it happen with a subject in the center of the image 5-6 feet way in "Green Square" mode?
02-19-2016 01:36 PM
yes, built in flash. and it doesnt matter if the subject is near or far.. or what mode i'm in.. i see the flash fire, but pics are very dark..
02-19-2016 02:02 PM
Try using flash with a very long shutter time. Does it flash right before the shutter closes?
02-19-2016 02:24 PM
i really am not sure if it is flashing before or after.. its seems to flash at the same time.. i can try adjusting my shutter speed..
02-19-2016 02:32 PM
This is just a test to check that.
02-19-2016 06:29 PM
Reset all settings to default in the menu. See if that helps. You could have dialed in negative flash compensation. Also be aware that the popup flash is really not much good farther than maybe 15 - 20 feet.
