camera stops working as pnp?
dor3y
Hey, I have a rebel t3 and it was working for quite sometime from usb to my pc, all of a sudden windows stops recognizing it. All my ports are still working everything else i plug in works fine. I tryed to find drivers and there are none? Is there something wrong with the camera?
1 REPLY 1
ebiggs1
You are correct. there are no drivers required or needed.  Is this a Windoze machine?
Most likely it is something you did. Not the camera.  First reset back to factory defaults.  Reboot your computer if you have not.  Get a new USB cable.  Use a different USB port.  Did you d/l or install any other/new software?  Any changes you made to your virus/firewall program, etc?   Try all the easy stuff first.
