07-02-2017 05:08 PM
Hello All ,
this is Kaoutar from Morocco , I had to register to the USA canon community because my country dont have that ,
well ; I really wish you could help me because I'm really having a bad time with my canon 5d mark II
it was working just fine , until I installed the magic lantern , I shot some vidoes with it , i took some pictures , everything was pretty normal , untill one day i turned it on and it was broken , it doesn't take pictures even though the shutter is released just fine , no images are saved , instead it shows a black screen with horizontal and vertical lines , the liveview is not working either , it's all black and get stucked ,
I removed magic lantern , I installed the 2.1.2 firmware twice , I formatted the SD CARD , I removed the battery several times , I even removed the small round battery and re instal it... I removed the lens ...I looked inside the mirror and behind it , nothing looks crashed , ...Im so so sad , because I couldnt find any one to repair it for me in morocco , do you have an idea ??
07-02-2017 05:55 PM
Get rid of Magic Lantern.
07-02-2017 06:02 PM
I did , problem wasnt solved , I think it's a hardware issue , because the same issue remains after removing the sd card
07-02-2017 06:11 PM
@kaoutar wrote:I did , problem wasnt solved , I think it's a hardware issue , because the same issue remains after removing the sd card
Maybe it is a hardware issue. Personally, I shy away from Magic Lantern. I would not tell Canon about ML if you send it in.
07-02-2017 06:13 PM
The horizontal and vertical lines could be a result that you have a grid enabled in the menus.
07-02-2017 07:12 PM - edited 07-02-2017 07:38 PM
If you have problem with ML, ask at ML forum.
5D II can´t use SD card without adapter. I wouldn´t use ML with an adapter and not with a wifi card.
With your symptoms it could also be a blown fuse.
