05-19-2017 02:48 PM
Great Blue Heron looks rather soft to me. Your thoughts.Shot with Canon 70D, EF-S 55-250mm @250MM, f 5.6. TV mode 1/1250, ISO 800
05-19-2017 05:22 PM
KV,
Thanks for your reply and I did crop this pic in Preview on my mac laptop as the original was too large to attach to my post and the only way I know is to crop it. So you are spot on as to resizing. Just still trying to get a grip on the af system and settings. Still learning!
05-19-2017 04:20 PM
It looks to me that the heron was in focus. The eye looks pretty sharp to me. It might be just the limit of what this lens can do.
I may be wrong but I think this picture was overprocessed? Also, this picture background is so busy I'm surprised it turns out this well. I too have many like this and I would not keep any of them.
05-19-2017 04:22 PM
It appears to be a copy and paste from some other program. Note the hint of a bounding box.
05-19-2017 05:19 PM
Diverhank
I was messing around with the original in Preview on my mac laptop pro and did change some coloring and tones etc and then I could not get back to the original so it could very well be overprocessed. I struggle with the af settings on the 70D and end up with out of fucous pics more often thn not. Thanks for your input, I appreciate it.
05-19-2017 05:22 PM
KV,
05-19-2017 05:27 PM
If you install Canon's Digital Photo Professional on your Mac you can see what focus points were used for the shot. (Unless, possibly, you use the distortion correction.)
05-19-2017 05:29 PM
Oh, and Photos will let you export the image at a lower resolution and keep the EXIF data we can use to troubleshoot.
