04-15-2022 03:17 PM
I have a new PC with Windows 11, and I installed EOS Utility 3.15 for Windows. My 7D Mk II connects perfectly through this version of EOS Utility, but EOS Utility does not recognize my EOS Ra. The computer does see the Ra; it shows up on the Device List as Unknown Canon Digital Camera, whereas the 7D Mk II shows up on the Device List specifically as the 7D Mk II. I have no problems connecting both cameras on a Mac through its version of EOS Utility. Anyone have any ideas? I am new to Windows, so maybe I'm stupid.
11-23-2022 03:51 AM
The issue is almost certainly the name. There's absolutely no way your computer can tell what kind of filter is in the camera. But EOS utility almost certainly has a hardcoded list of camera names that it works with. "R" is on there; "Ra" presumably was forgotten, and since it's such a niche camera, no-one at Canon noticed.
Good news is that this can probaby be fixed by Canon just adding "Ra" to the list of supported cameras. But that would be work, plus testing, plus the release process. So it's still not very easy.
11-24-2022 07:53 AM
I can tell you what I discovered with my EOS Ra. Partly, it was a USB cable issue. My HP computer would not recognize the camera on a 6-ft cable, but it worked on a 3 ft cable. I am told that this may be a function of the quality of the USB cable as much as the length, but I don't know that. Also, I had to experiment with different sequences of connecting the camera. IIRC, the camera had to be turned on before connecting. It may also depend on the PC you use. One thing I know for certain: none of these problems occur on my MacAir. The Mac doesn't care what kind of USB cord I use, or whether the camera is turned on or not; it just works.
