01-11-2025
02:05 PM
02:16 PM
I hope you’re doing well! I wanted to reach out because I’m in a bit of a tough spot. My old camera recently broke, and unfortunately, Kodak isn’t able to replace it. Photography is a passion of mine, and having a reliable camera means so much to me.
I’m hoping to get a new one that costs $800, but I’m struggling to cover the cost right now I was hoping to get an EOS R100. I was wondering if you might be able to help me out with this. I completely understand if it’s not possible, but I thought it would be worth asking. Thank you so much for considering it, and I really appreciate your time.
01-11-2025 02:15 PM
Thanks for joining the conversation, maxh3030! While we wish we could simply give away cameras, we can certainly beat that $800 price tag. We have EOS R100 kits in stock with prices starting under $500. Check out our selection right HERE.
Hope this helps!
01-11-2025 02:26 PM
You can get the EOS R100 you'll be limited especially in the flash department as Canon discontinues older flash products with the older 5 pin hot shoe. Everything is moving to the new multi interface hot shoe. A lot of higher end features will be unavailable. Such as the shutter closing down to prevent dust from getting on the image sensor. But otherwise it will work. Certain things such as expanding with that camera will be limited. Before upgrading to a newer body that has more features available. Certain lens features such as control rings on the lens won't work. All RF lenses have them but its not supported on the EOS R100.
