Want a 2nd Canon Body - Upgrade suggestions from EOS 80D
ibskiing
Hello,
I currently own a Canon D80 with the following lens:
  • Canon EF-S 18-135mm F/3.5-5.6
  • Canon EF 70-300mm F/4-5.6
  • Sigma 200-600mm F/5-6.3
I would like a 2nd body that is comparable to my D80, but an upgrade even slight would be preferable.  I shoot primarily wildlife and I am going on an African safari in June, planning to take my 18-135 and my Sigma 200-600.  Everything I have read suggested having two camera bodies and not trying to switch lens on a safari due to the dust. I would like to stay under $1,000 if possible.  Definitely looking for something that would have better light gathering capability.
I believe my Sigma is full frame compatible along with my 70-300.  Would you recommend a used full frame or one of the new more affordable mirrorless cameras, like the Canon RP.    I might even step up to the R8, which I have found for just over $1,000.
Thanks, Jim
13 REPLIES 13
Yes I know EF-S lenses can be modified to mount on Full Frame cameras. But I would NOT recommend it. This is a mode of unsupported mode of operation.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
As someone that has used the EF-S in a practical application on R bodies the results been quite pleasing. These images were shot on the R6 MK II with a EF-S 35mm f/2.8 Macro IS STM (Canon Adapter) in total darkness except for fill lighting. I have also used in on the R50 with the same results. AF works as well as the RF lenses.Even with the reduced MP you can obtain some incredible images.
Handheld f8 - 1/60 - ISO 6400
Marc
Windy City
To find common ground you must be willing to search for it.
Our interests intersect more than they diverge.
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
With a $1k budget, and the desire for additional light gathering capability, the R8 is a clear winner.  It checks the most "boxes".  It will also allow your FF lenses to shine.
I would recommend a monopod to help support the heavier adapted lenses while you sit for extended periods.
Other helpful items:
Plenty of spare batteries and memory cards.
An air puffer to blow away loose dust.
“Yes I know EF-S lenses can be modified to mount on …”
Your use of bold and all caps indicates that it is impossible. If you make absolute statements make sure you are accurate which is how it come across.
EOS 1DX and many lenses.
