View finder cap
Ramsden
Whiz
When I bought my EOS90D it arrived with a small strap with a view finder rubber cap attached. I thought this was just for protection, and fitted an eye piece and a better strap (or two).
Only today I read that the cap is to prevent light leaking into the camera and interfering with exposure.
So my question is, do you guys regularly use these caps and what are the benefits?
Ramsden
12 REPLIES 12
According to my EOS90D user guide, it says 'Cover the view finder to prevent light from seeping into the camera and affecting exposure'
It goes on to explain that the camera ships with a cover for this purpose.
First day on, so I'll check this out and see if my zone project photography improves.
Ramsden
“ Thanks, Waddizle, for the very helpful diagram. “
I don’t know where my original caps are, either. I don’t have a need for them. The caps are only needed when the camera is controlling one or more legs of the exposure triangle.
i typically shoot in M mode with ISO auto. If I neeed to use an OVF cap, then I will put my face on the OVF and read the ISO.  I will then dial in the ISO and take the shot.  This is what I do for most landscape shots and longer exposures.
ebiggs1
"..  I'll check this out and see if my zone project photography improves."
Yeah, let's see if you can tell the difference. I'm betting you won't see any or can't see any. There is no issue for  normal daytime photos. None. Your eye and head is in the way. Now perhaps if you are doing a long exposure on a tripod you might have an issue. I never have or had any personally. Long exposure means several to many seconds or minutes.
EOS 1DX and many lenses.
