01-01-2016 06:17 PM
I am in a low light setting with my T5 on auto and a standard 18-55mm lens.
When I focus on my subect, regardless of distance, the lens becomes very active struggling to focus and the flash *finally* pops up and takes the picture.
I tried disabling the flash as I've seen great effects in low light no flash with this model. The lens still struggled focus/unfocus over and over again.
This is a new camera for me and I want it to work! What am I doing wrong.
01-01-2016 07:57 PM
Sounds like light level is too low. You can enable flash assist to help focusing.
01-01-2016 08:14 PM
I saw a demo of this camera shooting a face illuminated only by candleight while set on auto. Is that not possible?
Since I'm just beginning I want to shoot on auto-everything until I get a feel for the camera.
Also, how do I go to menu and "make sure all settings are default?" as the manual instructs for beginning use? I don't know what the default settings are ...
I hope this makes sense!
Many thanks!
01-01-2016 08:27 PM
http://www.forums.usa.canon.com/t5/EOS-Rebel/Resetting-my-EOS-Rebel-T5/td-p/129099
01-01-2016 09:22 PM
Thanks for this John:
To reset your camera to the defaults:
Press MENU.
Select the [Tools #3] tab.
Select [Clear Settings].
Select [Clear All Camera Settings].
Select [Ok] to confirm.
However, MY camera (T5) does not have a "Clear Settings" option under any tab. Sigh.
01-01-2016 10:13 PM
01-01-2016 10:17 PM
01-02-2016 10:46 AM
Yes, camera is great outdoors. I just realized that mine has a low-light setting. I'll be trying that later this afternoon. My clear setttings are not as described above, but I figured it out and have reset all to auto in case I had tripped something earlier that was causing the problem. This is a brand new camera for me and my first DSLR so there's a learning curve even though my deep suspicion is that the Rebels are really point and shoots designed to look "professional!" 🙂
Thanks for the help and support!
01-02-2016 10:57 AM
