V Mount with R6M2 and Battery grip.
ian_t
I have the EOS R6M2 with the BG-R20 battery pack. As long as I’m using the original canon batteries, can I use a V mount via USB-C as a back up while the batteries are still installed in the battery pack? It’s normally used in a rig system and I did not want to remove the battery pack and put one in the slot and find the cover in the middle of a shoot. I was also under the impression that it’s safer to use USB-C than a dummy battery.
3 ACCEPTED SOLUTIONS
Waddizzle
Have you tried it, yet?
https://support.usa.canon.com/kb/s/article/ART177951
Depending on the model of your V-mount you can use it with a dummy battery or a standard Canon battery installed.  In fact the battery doesn't even have to be Canon OEM, but I recommend that's what you use.  I can confirm that it works with Canon or Watson batteries.  Important.  Make sure the battery has over 60% charge.  The V-mount will not charge the battery while the camera is on.  It won't deplete, but it won't charge and you always want 60% or more for high function (frame rates) etc.
Plugged in via USB-C PD. 5 V went off and assuming charging, and 9 V with the camera on. The battery has a voltage read out. Primarily why I bought that particular battery. Neewer PS099EP.
NEEWER Mini V Mount Battery PS099EP, 6800mAh 99Wh 14.5V V Lock Battery with 100W PD Fast Charging, Dual USB C/D Tap/BP/USB A/Dual DC Ports/OLED Screen, Compatible with BMPCC 4k 6k Camcorder Camera
4 REPLIES 4
Waddizzle
Thanks for your help. I wasn’t sure about the R6M2 with the battery pack. I’m assuming that if I have fully charged “Canon” batteries in the pack and connect the v mount via usb-c that I should be fine. I bought a V mount primarily for the R50 with a dummy battery. But wasn’t sure if I could use it for the R6M2 if necessary without pulling the battery pack off. Maybe it’s just good practice to pull the battery pack off with a fully charged battery installed. Wasn’t sure. I didn’t want to fry anything or ruin battery/camera.
