08-10-2013 08:39 PM
08-11-2013 11:15 AM
The T4i is an extremely good camera. The 6D will not be able to use your 18-135mm lens (full frame cameras cannot use "EF-S" lenses -- those lenses only work on APS-C crop-frame bodies), but it would be able to use the 50mm f/1.8 lens.
If you're in to taking hikes with your camera, you might enjoy the fact that the 6D has a built-in GPS so it can record where you were when you took the image.
Apart from the full-frame aspect, another very obvious difference on the 6D is the ISO performance. You'll notice it can shoot at higher ISO settings and have significantly lower noise as compared to your T4i. If you find yourself trying to push the ISO with your current camera and are unhappy with the resulting noise, then this will be a really big deal.
Other than that, owning quality lenses will make a bigger difference.
My scale of what makes the biggest difference in getting better images are (in this order):
1) You - your skill both in knowing how to capture exposures as well as artistically and compositionally.
2) Lighting - lighting is more important than lenses and will make a much bigger difference than anything below.
3) Lenses - it's not just "sharpness" -- its the character of the lens, focal ratio, how well-rounded is the aperture opening (number of blades), and how well the focus motors respond.
4) Camera body. While there certainly is a difference in camera bodies, the camera body simply needs to be enough to be up to the task you need. If it is, then it's everything above that will make the difference. If not, then upgrade the body. This is where I point out things like ISO performance with low-noise. But that only matters if you're taking photos that force you to push the ISO. If you're taking photos mostly in great lighting than owning a camera that does better at low noise isn't going to make thigns any better because every camera produces great looking images at ISO 100 in good light. The 5D III and 1D X have a fabulous focus system which is especially amazing for action photography -- but if you're not doing action photography it's a feature you wouldn't really need to pay to include in your camera. This is what I mean by the body being good enough that it's up to the task of what YOU need to shoot.
08-11-2013 12:30 PM
08-14-2013 08:32 PM
11-19-2013 09:56 AM - edited 11-19-2013 04:14 PM
IMHO, I would rate lenses as "number 1" in terms of best picture quality. A bad lens will never make a great photo.
Lenses is where it's at. The T4i is a pretty good body as it is. Remember lenses last bodies don't.
Also there are grades or levels in quality in the lenses made by every manufacture. The lenses you listed are Canon's consumer level. Almost all 3rd party, off-brand lenses fall into this category, too. (Some much worse!) Save for just a few specific models.
The 3rd party manufactures have made some strides in quality and you can find certain models are actually very good ones. Remember most are not, however. You have to know what you are buying. Canon does not reveal how they make lenses, obviously, so other manufactures have to reverse engineer theirs to work on Canon cameras.
I am going to recommend you invest in glass, first. Although the 24-105mm f4 IS is not very wide on the short end it is a fantastic choice for a first lens in the "L" category. The T4i will make it seem longer on the 105mm end so there is a give and take there. The 17-40mm f4 L is a very nice lens on a T4i. It is going to be a more "normal" lens range on a T4i.
Either of these will work on a FF if you decide to go that route next year.
Nix the 50mm f1.8 and get the 50mm f1.4 instead. IMHO, of course!
11-19-2013 10:55 AM
@ebiggs1 wrote:A bad lens will never make a great photo.
Any lens manufactured today can make a great photo. I've seen great photos made with a camera phone.
That said, if the OP has money burning a hole in his pocket, +1 to the 24-105 and 50/1.4 combo. Add in a macro lens and I could be a happy camper in a lot of situations.
11-19-2013 11:15 AM
I have no doubt you have!
11-19-2013 11:20 AM
Just like the kid that came up to me yesterday and said, "Mr.Biggs I just got an app for my ipad that lets me do everything Photoshop does."
I told him, "Sure you do."
To each his own................
08-14-2013 08:50 PM
11-19-2013 11:00 AM
@ScottyP wrote:
What EXACTLY do you shoot?
This really is the base of the issue. The 24-105 is an all around lens, and given the focal lengths you shoot at it's kind of a no-brainer given its reduce pricing. Beyond that, it depends on what you shoot. As I mentioned above, I'd probably get a 50/1.4 and a macro lens if it were me. However, many photographers rarely take their 70-200 off their camera, you could get the 70-200/f4 IS in that budget. And other still, nature photographers/architectural, would get an ultrawide like the Canon 10-22. Unfortunately that wouldn't work if you move to full frame, but I still pull out my 450D just to use my 10-22. It's a great lens, and wonderful in the outdoors.
