04-24-2013 02:25 PM
I have a 60D and am getting a lot of noise in the sky even at 200 ISO. Does anyone else have this problem?
04-24-2013 02:38 PM - edited 04-24-2013 02:38 PM
Are you zooming into a 100%? There's always going to be some level of noise in any digital picture, and it's subjective to say what is a lot of noise and what isn't. But in general you're 60D shouldn't have any noticable level of noise, especially in a blue sky, at ISO 200 when viewed at a normal size.
Can you post an example?
04-24-2013 05:12 PM
Even at low ISO, you'll see good chunck of noise if you use High Tone Priority.
04-24-2013 07:04 PM
The sky was noisy on images from my 7D at 100% or even 75% but you don't print at that high a magnification so it wasn't a real issue in real world terms.
05-02-2013 10:01 AM
Canon support suggested it might be because I had the "Auto Lighting Optimizer" feature set to "Strong". I didn't even realize that setting existed, but I change it to "none". Unfortunately, I haven't had a blue sky to photograph since I made the change, so I can't tell yet if it helped. Is that what you mean by High Tone Priority, or is that a different setting?
05-02-2013 11:46 AM - edited 05-02-2013 11:46 AM
They're 2 different things. One used to protect the highlight and the other used to lift the shadow. But both of them make image some what noisy because it is boosted via in-camera-post-processing.
05-02-2013 04:31 PM
OK, I'll check that one out too. Thanks. I prefer to do my own processing in Lightroom.
05-02-2013 05:15 PM - edited 05-02-2013 05:17 PM
@Picturegal wrote:Canon support suggested it might be because I had the "Auto Lighting Optimizer" feature set to "Strong". I didn't even realize that setting existed, but I change it to "none". Unfortunately, I haven't had a blue sky to photograph since I made the change, so I can't tell yet if it helped. Is that what you mean by High Tone Priority, or is that a different setting?
Auto Lighting Optimizer and Highlight Tone Priority are useful functions, but it's very likely to get noiser images (in dark areas) if you enable any of them. Especially if you had ALO set to "strong".
Shoot the same scene with and without any of those functions enabled and you'll see the difference.
When they're well used they can give you great result, but you have to be careful to avoid excesive noise increase in dark areas.
Regards.
05-02-2013 06:29 PM
05-02-2013 07:41 PM
When I look in my manual for Highlight Tone Priority settings, they seem to be for movie shots, not stills.
