09-07-2026
08:30 AM
02:32 PM
Hello
I feel a touch silly writing this post, but here goes. While I'm at home I tend to swap lenses in the safety of my home, but this summer, while on holiday I changed my lens a couple of times while out on walks. I thought I was very careful but ended up with what looked like a thumbnail shadow on my photos. Quick investigation and worked out it was my camera.
I nervously used a puffer and light brush on the mirrors and it cleared up. Except, it came back this weekend.
So this time I pressed the shutter with the lens off and saw the offending object, which was a tiny hair or fibre. Thankfully I was able to remove it with the puffer. So all good.
My question is based on looking for good ideas for safety exposing the camera and lenses when out and about.
I think I'm careful, but clearly not careful enough.
Any tips welcome
Ramsden
Plus really recommend having a good puffer!
09-07-2026 03:03 PM
Roger
Thanks for another motivational post. It must be quite an emotional process resting up a 20+yr old camera. So many memories.
I personally, would be very nervous undertaking a big clean as you describe.
I'll certainly be holding my camera down, if I do decide to change a lens. So I've got something to take away.
This has been such a positive thread, and I'm really pleased I asked the question!
Ramsden
09-08-2026 07:53 AM
“I'll certainly be holding my camera down, if I do decide to change a lens.”
In addition to keeping your camera pointing down, put your back to the wind (if there is any). What also do is first place the lens I’m about to use on a flat surface (even on the ground with a rag under it). I then loosen the back cap so I can simply lift it off; be sure to orient it in the right direction (red dot or line pointing the same direction as the camera’s one). Remove the lens on my camera. Set it down next to the other lens, swap the back cap to the “old” lens and attach the “new” lens. Make sure you remember to tighten the back cap before stowing it.
Practicing changing lenses at home also helps to build your confidence and create muscle memory.
09-08-2026 09:36 AM
Boy, you guys are a lot more "careful" that I am. However, do what you see is best common sense rules.
09-08-2026 11:10 AM
Jeff, thanks for those tips.
I'd written (in my head) a short procedure which highlighted that vulnerable second or two when the camera is exposed at the time caps are being swapped, and new lens being offered up.
The back to the wind, and particularly the cloth are great additions.
In my day to day walks, I wouldn't normally be planning to swap lenses, but holidays always throw up something new.
A clean cloth is now in my camera bag!
Ramsden
