04-01-2024
11:07 AM
09:11 AM
Many times I have taken photos and then later when I download them I was sure of the subject. Like if I took a photo of a piece of equipment or large engine I could not remember the name of the subject in the photo. What is a good method to take notes or somehow be able to ID the subject later, other than a placard that is by the piece?
04-02-2024 01:33 PM
OK, so what I need to do is display the photo # with the photo in the viewer. Thanks.
04-02-2024 02:12 PM
I have used a pen and paper sometimes.
You might also record a short video where you say what information you want saved. If you have enough storage.
04-03-2024 10:02 AM
I'n the old days I would take a notepad, then write the info on the back of the pictures after they were developed. These days it's as simple as opening any note app on your phone, and using talk to text. Later save it to your metadata in your editing software OR rename the filename of the photo.
04-03-2024 07:51 PM
Adding: voice recorder? Some are very small to carry in a pocket or vest.
04-04-2024 04:36 PM
As Tintype_18 mentions above, a small digital audio recorder should do the trrick.You can find them pretty cheaply online and most seem to have a setting that allows them to be voice activated. You might also be able to synchonize the clock on your camera with the recoeder to help keep things oganized by comparing the time stamps on your pics and the audio clips.
Another approach might be to use the video cam on a cell phone. Shoot your stills and then shoot a short video clip of your subject while adding an audio description. Then review the video while sorting and annotating your stills.
04-04-2024 04:47 PM
On a phone you can probably get Siri to create an entry into the note app. (Or the android equivalent)
04-06-2024 03:46 PM
Lots of great ideas! Thanks.
