12-29-2020 08:07 AM
Coming from a T5i, my T6s focusing is different. I'm not able to get 1 dot focusing point even though following directions on videos I've seen.
I select 1 pt AF but when trying to take a picture, I still get several
Any help is appreciated
12-29-2020 12:38 PM
changing lense made no difference. Still unable to get a single focal point even though it's set that way
12-29-2020 01:11 PM - edited 12-29-2020 05:19 PM
@cruisinfanatic wrote:changing lense made no difference. Still unable to get a single focal point even though it's set that way
What is the setting on shooting mode dial on the top of the camera? Set it to "P". Find the [main] setting to reset the camera back to factory defaults. Reset the camera.
If you are in any of the "Basic" automatic modes, then you have no control over AF point selection. Also, the camera reset option will not appear in the menus when you are in any of the Basic shooting modes.
Set it to "P". Put the camera into One Shot AF mode, using the [Q] Quick Menu screen. Try to select just the center AF point, following the instructions provided above. I do not think the lens has anything to do with it.
12-29-2020 03:01 PM
"I do not think the lens has anything to do with it."
I agree but you could do a whole lot better with a better lens. Just my humble opinion.
Do as the man says...................
"Set it to "P". "...following the instructions provided above."
BTW, a reset can't hurt either, set it to P before you do it.
12-29-2020 05:37 PM
We have a Canon EF-S 55-250mm also. Something better that you'd suggest for birding that isn't too huge?
12-29-2020 07:20 PM
Tamron lies to the camera so it can focus at f/6.3
12-29-2020 07:22 PM
Again, as long as the point you have selected lights up, any other point in focus will light up, too.
I leave mean in area mode with the center section.
12-30-2020 10:20 AM
OK, remember you asked because this is off topic. There is a problem making a zoom lens that has such a huge focal range.
It's not just your Tamron 16-300mm. It is most any zoom with a 10 to one or more FL. I will bet you use the lens at the 300mm end far more then you do at the 16mm end especially when you are birding. This lens is at it worst at the long end. Lots of CA and distortion. Focus breathing at short ranges means you don't actually get 300mm, more close to 250mm. The AF, although not the cause of your issue, is below average and not reliable at the long end, too.
Unfortunately a, good, big tele for birding is, well,... big! Another choice is, since I bet you are at 300mm mostly while birding, why not get a 300mm prime lens. Not as big. Not too heavy. A lot faster and top notch IQ.
However in the end it is you that must decide whether you are satisfied, not me, with the output of your gear. If it does what you want then don't pay any attention to any of this. Go out and enjoy it.
12-30-2020 11:10 AM
Thanks for advice
