08-06-2019 01:53 PM
My T6 will not produce any images when using live view, but will when using the viewfinder. AND - this problem ONLY occurs when using the 18-55mm lens, not the 70-300mm lens. What gives???
08-09-2019 12:38 PM
08-09-2019 01:30 PM
I know, but the symptoms are inconsistent. He says it works with the 75-300.
04-09-2024 11:33 AM
Having same issue with my wife's T6 Rebel and the 18-55 lens. If using the viewfinder, autofocus works with a half press and you can take photos with a full press. If you are using the rear LCD instead, any press of the shutter button (half or full) will trigger the shutter but no image is saved.
04-09-2024 11:39 AM
Does live view work in manual mode as in the OP?
