05-10-2013 11:54 AM
Hi there
The T4i my partner got doesnt seem to record HD videos longer than just a few seconds. She is NOT using the video snap shot mode to capture video. Videos captured in 640x480 mode can record for quite a long time.. over twelve minutes. She has emptied the SDHC 16GB card totally and still faces the same problem.
Any suggestions as to what may be causing this?
Thanks
05-10-2013 07:01 PM
The manual recommends a class 6 or higher. Any class 10 will work for video.
05-10-2013 04:31 PM
Most likely it's the speed of your memory card. Make sure you have a fast enough card for HD recording. If the buffer fills up, it will stop recording.
05-10-2013 05:05 PM
Thanks for the reply. Could you reccomend a card which would be fast enough for this camera? I dont know much about rebel series as I have a 5D M2.
Thanks again
05-10-2013 07:01 PM
05-11-2013 01:37 PM
I had the same problem and I finally solved it by getting a Lexar 32GB card. Jim
05-11-2013 02:49 PM
Is that one a class 10 card? Thanks for all the replies.
05-11-2013 05:10 PM
I am sorry I have no idea what class it is ,I just know I was using a class 6 but at a lower GB then Canon asked me to try a diff Class 6 card so I did but at the same lower GB and that did not work. I suspect the problem is not with the class but with the size of the memory of the card, movies require a lot of memory so the bigger the better. ( I do not think the class # has anything to do with memory but probably something to do with download speed) I think you need both speedy download and large memory. I am no expert I just know what worked for me. Jim
