12-07-2025 09:30 AM - edited 12-07-2025 09:41 AM
Leaf-2.jpgI recently bought a R5 Mark II and have generally been loving it. My previous camera was a 15yr old Canon Rebel XS, so most of my lenses are EF. I therefore bought a genuine canon adapter to use them with my new camera body. Today I took some macro photos and started to notice the image quality was much poorer in my viewfinder as I was taking the photos. Lines started to appear in my images, which is a big dissappointment. Has anyone else experienced this, and if so how can I rectify? I'm hoping it isn't a problem with the camera itself.
12-07-2025 09:56 AM
Greetings vic_78, and welcome. Your first post here.
Rebel XS > R5 mkII...that's quite an upgrade. I assume these lines are only happening with your macro photography?
Are you using electronic shutter? What type of lighting are you shooting under? Are you using a flash?
12-07-2025 12:29 PM
Hey Rick, thanks for your reply. I thought it was time for a proper upgrade 😉
I've only noticed the lines whilst taking macro photos. I use a portable LED light that has adjustable brightness and temp. I notice it more with wider apertures, and lower light conditions. Both of which I'm fond of using for the shallow DOF and subtle lighting.
This sounds utterly ridiculous, but I have no idea whether I'm using an elecronic shutter? I'm still getting used to the big jump in hardware.
12-07-2025 01:33 PM
Some LED lights adjust their brightness by rapidly turning on and off. Is it possible that is what you are seeing?
I have EOS R5 first version, but I hope some of this might be helpful anyway.
I usually use electronic first curtain shutter. https://cam.start.canon/en/C017/manual/html/UG-03_Shooting-1_0310.html
Anti-flicker shooting:
https://cam.start.canon/en/C017/manual/html/UG-03_Shooting-1_0020.html
https://cam.start.canon/en/C017/manual/html/UG-03_Shooting-1_0080.html
Images may be affected by banding if you shoot under light sources that flicker at high frequencies. High-frequency anti-flicker shooting enables you to take pictures at suitable shutter speeds for high-frequency flickering, which minimizes the effect of this flickering on images.
Caution
: Same expo. for new aperture] to [ISO speed].
12-07-2025 03:11 PM
Hi John
Thank you for the links. I do think it's something I'm either doing or not doing correctly. I'l check them out.
Thank you very much
