10-30-2021 05:38 PM
Hi all,
Purchsed a used Sigma 105mm F2.8 EX DG HSM off eBay. Research says that it should fit the Canon SL2. However, the lens will not turn to lock in. It does fit snug into the mount, just doesn't turn. On inspection the lens is super clean and I don't see any damage around the mount area. Thoughts? Want ot make sure I'm not missing something before requesting a refund, thanks.
Apologies for the double post (also in lenses), if that's an issue.
10-30-2021 05:50 PM
Are you sure it has a Canon mount, that lens is also available with a Nikon mount.
10-30-2021 06:10 PM
DG is for Canon... I found the issue thought. There is a screw not screwed in all the way - seems to be stuck. Not sure how this guy tested this for functionality as stated in the listing. Refund started.
10-30-2021 06:40 PM
Hope your refund goes smoothly!
10-31-2021 04:05 AM - edited 10-31-2021 04:06 AM
@tester tips wrote:DG is for Canon... I found the issue thought. There is a screw not screwed in all the way - seems to be stuck. Not sure how this guy tested this for functionality as stated in the listing. Refund started.
That is incorrect. The "DG" designation simply means that the lens is designed for full frame bodies. There is nothing in the model number that tells you what type of full frame lens mount the lens is made for.
Send it back for a full refund. It sounds like you may have the wrong lens mount, or a DIY repair gone wrong.
10-31-2021 04:17 PM
