06-14-2013 12:24 AM
06-14-2013 11:04 AM
Not sure if a viewfinder enlarger will help or not. They're not very expensive, give it a go. You could also try a diopter adjustment lens and not use glasses, but of course you wouldn't be able to chimp.
Also not sure if the larger viewfinder in a full frame would be benificial or not considering your tunnel vision. I'd definitely try one before buying.
But now that you mention it, I guess I don't really look at the setting in the viewfinder that much. I'm mostly on the back LCD, though I'm transitioning to the top display now that I have one.
06-14-2013 11:47 AM
06-14-2013 03:50 PM
I haven't, but I've never really had too much trouble seeing the LCD. I'm new school I guess, I chimp constantly and I'm always checking my histogram. Probably why I don't use the figures in the viewfinder.
06-14-2013 10:19 PM
06-17-2013 12:01 PM
@dean_nash wrote:
I should spend some time learning some new school methods like using the histogram. I think this woukd help not having so much post production lightroom work.
Here again I sure miss the magic of film. thanks for your reply and insights.
The histogram is the single most underused tool in the digital photographer's arsenal. If used properly you shouldn't have to do more than minor exposure adjustment for mood.
06-14-2013 09:16 PM - edited 06-14-2013 09:18 PM
The Eyepiece Extender will not help... in fact it might make matters worse for you.
You should do as suggested and get an accessory diopter so that you can shoot without glasses. There are various strengths diopters available, which then can be fine tuned with the built-in adjustability. You might need to have one made (not sure where you can get that done) but Canon seemed to have quite a selection. Your optometrist might be able to tell you what strength you'll need to get in the ballpark (then fine tune with the adjustable diopter).
Yes, I have tried one of those folding hoods over the camera's LCD. I lost it the second or third time out... .it fell off while I was carrying the camera. So, needless to say, I wasn't impressed. It did shade the LCD pretty well, though.
I've seen magnifying loupes that might work, too... sort of look like an old "chimney finder" for a twin lens reflex camera.
There are bigger and brighter accessory LCD screens available, too. They are pretty expensive, though.
60D or one of the other models with an articulated LCD screen might be easier to see, too... since you can adjust the screen's angle as needed.
I shoot with glasses on, too... and can't see the readout normally, but can when I shift slightly (with 50D, 5DII, 7D). I don't have any tunnel vision issues, though.
I'd suggest you check out 5DIII in a shop before purchasing. I believe it's a 100% viewfinder (the 5DII's isn't). That might help a little. 7D also has a 100% viewfinder.
06-14-2013 10:14 PM - edited 06-14-2013 10:22 PM
