11-05-2021 10:47 AM
Hello, I've had my SL2 for 2 years now and while I was looking through the manual last week I discovered that it was supposed to beep when focus was achieved. My SL2 has never done this. The Beep is Enabled in the settings menu.
It does beep at other times, like when I activate the menu and start moving from screen to screen in the menu. It just does not beep on focus. I've tried different lenses and no difference - no beep on focus. I do get the other indicators in the viewfinder that it's focused, just no beep.
Is there some other menu setting that may be affecting the beep on focus?
11-05-2021 03:16 PM
It is very soft, how are your ears?
11-05-2021 06:20 PM
11-05-2021 06:34 PM
Have you tried resetting the camera to its defaults through the settings menu yet?
11-05-2021 06:48 PM
Also with it set to AI Servo AF the beeper will not work
11-05-2021 07:25 PM
@John_ wrote:Have you tried resetting the camera to its defaults through the settings menu yet?
Yes, I have.
11-05-2021 07:29 PM
@John_ wrote:Also with it set to AI Servo AF the beeper will not work
It's set to One Shot.
