Rebel t3 won't take pictures and now there's a floater when I look in the viewfinder
Quinn124
I've had my camera for 8 months and it just stopped working. I've been in contact with Canon about the camera not taking pictures. They've given me some troubleshooting to try and so far it looks like a lens issue. The last instructions I was given said to remove the lens and clean the metal contacts, which I did. After doing that now I see a floater when I look through the viewfinder. Any ideas?
2 REPLIES 2
TCampbell
Does this only show up when you look through the viewfinder? E.g. Does it appear in a photo or in live view mode?
If only in the viewfinder then you may have a bit of dust, etc on the focus screen.
Using a hand-squeeze blower (e.g. A Giotto Rocket Blower, etc. avoid cans of compressed air because they can spray some propellant which leaves a hazy residue.) to gently blow out dust.
The focus screen has a fine textured surface and if you touch the screen you can easily make things worse.
Tim Campbell
5D III, 5D IV, 60Da
ebiggs1
What did you use to "clean" the contacts?  If it was a q-tip, you probably got a piece of fuzz from it inside the camera.
You can try a blower, like the Rocket Blower, and see if it removes it.  But remeber there are lots of stuff in there that don't do well after being touched!
