Rebel XT not giving sharp images
cgross
Hi
My Rebel XTis not giving me sharpen images lately. It's served me well for years. Do I throw it, or is there a way to refurbish, refresh it?
is it worth putting any money into it, or is it time to upgrade?
Is the Rebel still top of the line for personal photography? or is the EOS M50 a better option today?
I will appreciate any help I can get,
C Gross
13 REPLIES 13
Tronhard
VIP
VIP
Hi and welcome to the forum:
Given that the Xt is an interchangeable lens camera, if you are not getting sharp images any more, and you want to keep the camera, it might be worthwhile seeing if you can try another lens attached to the same body.
If it turns out to be the lens, you could easily get a replacement, or much better unit as optics have come a long way in 19 years.  What is the precise description of your lens - as you would read it from the front face of the lens?
The Rebel series was Canon's consumer brand, above which where the enthusiast cameras with an ID of ##D e.g. 60D, 70D, 80D; and then the prosumer and professional cameras with the #D designation: 1D, 5D, 7D.  Given that the XT model was released in 2005, if it turns out the camera itself is the issue, you will not be able to get it fixed, nor would it be economical to do so.  You can get a newer DSLR camera that will be far more powerful, but will feel much like your XT - new or refurbished, but that market is shrinking as Canon move to an other platform.
As far as the EOS M series is concerned, it was at the the consumer and enthusiast levels, but has been completely retired by Canon in favour of the new R-series Mirrorless Interchangeable Lens Cameras (MILCs).   They have been around for about 5 years now and this is where the development is, and has an expanding range of bodies and lenses.
If you decide to go for a new camera and lens there is a trade-up program that Canon offers. If you were to choose a new camera, we can help you with advice on what models might be best for your purposes, but let's see how the measure of changing the lens works out first.  Replacing the lens will be the cheapest solution.  See if you can borrow another lens for even a short time to check if the lens or the body is at fault.
cheers, TREVOR
rs-eos
Can you provide example images?
Do you recall making any changes to settings? You can always reset the camera back to factory settings and see if that addresses the issue.  See page 147 of the User Manual.
If you end up moving to a new camera, yes, avoid the M-series cameras as they were discontinued.  Look at the R-series camera line which starts with the EOS R100.
Ricky
Waddizzle
The camera is most likely not to blame.  A camera will only record what it sees.
kvbarkley
Can you get a sharp image if you focus manually?
I will try out changing the lens. I don't have the camera with me now, but will get back to you with regard to which lens I have.
thank you for taking the time to write!
I hope I still have the user manual. Is it available online for such an old model?
That is a very good question and I will try it out!
You can click on the link to the User Manual I had provided in my earlier response.
Ricky
Let's hope it's just the lens.  There are lots of choices out there for your type of camera and an new one may open up many more photographic possibilities and seriously improve your images.
cheers, TREVOR
Friends and Family
