11-23-2020 09:42 PM
I am using my Rebel T6i to film hunts. I am using the lens that the camera came with,18-55mm. I want something that can reach out further and still be good for when I need shots up close. What would you guys recommend?
11-24-2020 12:35 AM - edited 11-24-2020 12:35 AM
The whole point of a T6i is to change lenses for different needs. I would suggest an ef-s 55-250 to add some reach along with the kit lens, and a ef-s 60mm macro for really close shots.
11-24-2020 09:10 AM
Thank you for the info! Im pretty new at all of photography/videography stuff so any info definately helps.
11-24-2020 09:35 AM
@ZSUNTKEN wrote:Thank you for the info! Im pretty new at all of photography/videography stuff so any info definately helps.
I always tell people who are new to videography that you must FIRST be a good photographer. If you do not know how to capture great stills, then you may never get the hang of capturing great video, which is basic photography on steroids.
As to your immediate "problem" of having a camera that can better zoom in, the above lens suggestion is a good one. I would only add that you may want to consider using a "B Roll" camera for such shots. That means a 2nd camera for the long shots.
