01-09-2025 01:16 PM - last edited on 01-09-2025 01:18 PM by SamanthaW
hi, I just bought a refurbished Canon Rebel T6 off KEH. It works OK, but when I put my SD card in, it won't turn on. I take the SD card out and the battery out and then put the battery back in, then the camera will turn in again. I'm so confused, the SD card works with every other device I have just not this one. It's a 128GB onn. brand (like target brand) has anyone else had this issue? what kind of SD card works with my camera? thanks!
01-09-2025 01:25 PM
Is it a full size card or micro with adapter. Canon's have issues with micro cards.
The obvious suggestion is to try another card.
01-09-2025 01:39 PM
thank you!!
01-09-2025 06:18 PM
A 128 GB card is really overkill, and the camera may not like it. Use cards of 16-32 GB, which will hold thousands of photos, a lot more than you should keep on the SD card.
But the 128 should not keep the camera from turning on. Call KEH for possible return of the camera.
01-09-2025 09:39 PM
When you turn on the power with an SD card installed, does it red LED turn on or flash on the rear panel somewhere?
Have you checked inside the card slot?
01-14-2025 01:28 PM
yes, it does flash red once.
