10-21-2015 09:03 PM
Okay, I know that to attach an external flash unit to my T5i is to physically connect the flash unit to the top hotshoe on my T5i. That is too obvious. BUT, how do I go about getting my T5i to RECOGNIZE and utilize the external flash unit? I've looked through my menu screens but they are for the INTERNAL pop-up flash, which is built-in.
Thanks for the speedy response to my previous questions on my T5i.
10-21-2015 10:29 PM
Not sure I understand your question. What flash do you have? Have you mounted it in the hot shoe but it isn't working OR are you trying to use it off camera?
10-22-2015 09:09 AM
To use off camera flash, you need an ETTL cable or a wifi attachment, or trigger. Either is readily available at camera stores like B&H or Adorama, etc.
10-22-2015 10:09 AM
Which flash (model) are you using? Is it a Canon flash?
10-22-2015 10:56 AM
Vivitar DF-383 for Canon cameras. I will be upgrading to a Canon external flash unit sometime next year.
10-22-2015 11:08 AM
I never used that flash but it may not be an ETTL capable unit. If not that will make it more difficult.
10-22-2015 11:14 AM
It should be ETTL.
10-22-2015 11:21 AM
Check the specs.
10-24-2015 09:05 PM
@scottjg24 wrote:Okay, I know that to attach an external flash unit to my T5i is to physically connect the flash unit to the top hotshoe on my T5i. That is too obvious. BUT, how do I go about getting my T5i to RECOGNIZE and utilize the external flash unit? I've looked through my menu screens but they are for the INTERNAL pop-up flash, which is built-in.
I've not used a T5i, but I believe that generally those menu screens come up only when the external flash unit is mounted on the camera and turned on. Also, you may have to use a menu on the unit itself to make it tell the camera that it's present and functioning as a Canon-compatible flash. In any case, your T5i manual should include a chapter on using external flash. (On some recent models, the printed manual is abbreviated. So if you don't find such a chapter, look for a more complete manual on the Canon Web site or on the CD that should have come with the camera.)
