04-11-2014 10:39 AM
Normally when I turn the camera on I get a busy signal when I try to take a picture or press any buttons on the back of the camera. I also get the busy signal inbetween taking pictures sometimes. I have tried switching between a class 4 SD card and a class 10 SD card. I see no difference when switching between them. When I get the busy signal between pictures, I am not taking them at a fast pace. I have even gotten the signal after I haven't taken a picture for a few minutes and then go to take a picture. I updated the firmware even though it had the latest firmware and did not notice a difference.
04-14-2014 06:43 AM
Hi aaronh!
Thanks for posting.
It is very likely this is being caused by the flash. When the flash is being used, the camera must wait until it is charged and ready for each shot. During this time, a "BUSY" message is displayed. This is completely normal. You should notice that this message does not display if you switch to the No Flash mode and try to shoot a few images.
04-14-2014 08:49 AM - edited 04-21-2014 08:20 AM
No that did not fix the problem. The camera had been sitting all weekend, and I switched the control to no flash, turned the camera on and couldn't take a picture right away. I still got the busy signal when I tried to take a picture or tried pushing buttons on the back. I couldn't get into the menu or look at old pictures.
