RF lens won't fit on EOS Rebel T3i
Dreamphotos1
I just purchased a lens for my EOS Rebel T3i. The lens I purchase was the RF 14-35mm f/4L IS USM Ultra-Wide-Angle Zoom Lens for RF Mount Canon. The lens will not fit on the camera. Did I purchase the wrong lens?
9 REPLIES 9
rs-eos
Yes.  RF lenses can only work with RF-mount cameras and cinema cameras.
Your camera can only work with EF or EF-S lenses.  Hopefully you can return the item (though it is opened, so not sure on the return policy from where you bought it).
Ricky
Camera: EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L
Hopefully, you have enough to upgrade your camera to an RP.
Tronhard
Definitely you want another lens.  Since you have a crop-sensor camera the best lenses would be: an EF-S type, which are specifically designed for this sensor- I have all of these and they are all great lenses.
Canon EF-S 17-55 f/2.8 IS USM - a very good lens  - this is arguably Canon's best APS-C lens.
Canon EF-S 15-85mm f/3.5-5.6 slightly wider aperture, and a really good lens - I have two of them!
Canon EF-S 10-22mm f/3.5-4.5 gives you a range of wider angles if that is critical to you.
Definitely return the RF lens and get one of the above.
cheers, TREVOR
"The Amount of Misery expands to fill the space available"
LloydL
The Canon EOS Rebel T3i is available bundled with the EF-S 18-135mm f/3.5-5.6 IS lens. This lens has agenerous (for a kit lens) and versatile optical zoom ratio of 7.5x with a 35mm equivalent range is about 29-216mm, because of the T3i's ~1.6x crop factor.
Given the OP deliberately purchased a lens that was ultra-to-medium wide angle (14-35), the question is whether the 18-135, which is a good general-purpose unit, is really what they want.   I deliberately looked at lenses that would be more in the range for which they showed a preference.
The EF-S10-22mm, for example, has an equivalent FoV of 16-35mm, which is VERY close to the range they chose and is, I suspect, as close as possible to their intent.
cheers, TREVOR
Kashifr
Hi
I also have T3i. From last few weeks I am researching to upgrade and found RF 24-70 f2.8
Two days ago I contacted Canon and they said I can use it with the adaptor. For some reason I contacted Canon again today, and this time the rep said I cannot. So now I am confuse. But for sure Canon has untrained staff and I cannot trust them completely.
Anyone has any idea about using the adapter?
Thank you
Hi Kashfir:
For best results you should actually start your own thread, otherwise it gets confusing for all.
That said.  You definitely CANNOT use an RF lens with any other cameras except R-series bodies.  That means they will not work on your camera.
If you want a lens for your camera, consider an EF or EF-S (NOT an EF-M) lens.  As a general purpose walk-around lens, good for some landscapes, social photography and portraits, I would suggest the
EF-S 18-135 f/3.5-5.6 IS USM: if you can't find a new one, there are lots of them available on the used market - consider KEH.COM.
cheers, TREVOR
I am sorry Tronhard,
I posted on this thread as the camera and the lens is same as my choices. I will continue on the new thread. My apologies 🙂
Thank you
No worries, thanks for making the effort! 🙂
cheers, TREVOR
Avatar
