08-17-2022 02:50 AM
Why, why, why? Will the R6 not focus? I always get the red square when I focus on the eyes - and not the green. And yet when I switch to manual AF it's focusses fine.
Settings are:
ISO: 200
Shutter: 160
Aperture: 7.1
Lens: EOS 70-200mm
Focal Length: 85mm
HELP!
08-17-2022 02:55 AM
If this happens when using the strobe have you checked that focus assist is enabled for flas photography?
08-17-2022 02:58 AM
Oh no, I didn't even know about that function.
Will look it up and check my camera setting (in the morning :))
Thank you so much. I will update on the morrow.
Best,
Josie
08-17-2022 03:07 AM
Sorry - I might not have made myself clear. Why won't it focus on AF?
The focus assist works only for the Manual focus setting - is that right? Which by the way, it does when I set the camera to manual focus. Works great.
But I want to auto focus using the strobe.
08-17-2022 04:04 AM - edited 08-17-2022 04:05 AM
What kind of flash unit are you using?
If you look on P153 of the user manual, is says "the Speedlite will automatically fire a focus assist beam as needed, if autofocusing is difficult under low light". Thus this should work: if it doesn't check your Speedlite settings and if necessary refer to its documentation. If it is not a Canon Speedlite, definitely refer to the flash maker's documentation.
08-17-2022 04:26 AM
Thanks!
I'm using the Godox 400AD Pro. Have just done a quick search and there doesn't seem to be a focus assist beam with this model/brand?
You're right, I think it's a low light thing. Frustrating. I'm not sure why all of a sudden it won't auto focus when it has operated in similar set up, before.
08-17-2022 04:28 AM - edited 08-17-2022 04:29 AM
If it DID work on this camera before, perhaps do a camera reset and see if some unknown setting has changed the situation?
08-17-2022 04:31 AM
Thanks, Trevor.
Yes, will try that. Was trying to avoid resetting so that I don't lose my awesome presets - but the pain of not having autofocus is far greater.
Will see how it goes...
08-17-2022 04:35 AM
save your current settings to one of C1-c3 modes, before you do a reset?
08-17-2022 04:36 AM
omg - YES! Thanks. Heaps. (NZ slang)
