05-27-2023 11:47 AM
I have a R5 with 1.7.0 currently installed. I have downloaded the 1.8.1 update and placed it on a formatted CFExpress card. ( I'm on a Mac with Monterey 12.6.2) When I put the CFExpress card in the camera and go to the Firmware menu item it shows that I have 1.7.0 and when I try to update it I get the message "Firmware older than ver 1.7.0 is on memory card. Delete old file and update using later version".
The firmware file I placed on the CFExpress card is EOSR5181.FIR
Interestingly if I look at the file info of the .FIR file on the computer it says the Date Created is March 12, 2023 and the Date Modified is March 9, 2023. Seems it was modified before it was created.
Any help is greatly appreciated.
Bill Plunkett
05-27-2023 12:25 PM - edited 05-27-2023 12:46 PM
Using a SD card was recommended for prior updates. It looks like v1.8.1 (might) allow either card type now. Its not spelled out specifically like it was previously. I always use a SD card for firmware updates. Did you format the card in camera before copying the .FIR file to the card?
I'd remove whichever media card is not being used for the update. The error you are describing usually means the camera is seeing an earlier copy of the FW.
We see this most commonly when the EOS utility was used previously to download FW. If you don't use a freshly formatted card things can "stick around". The "one card" inserted rule always seems to work.
05-27-2023 12:04 PM
Is "EOSR5181.FIR" the only firmware file on your card?
I wouldn't expect the modification date to cause this issue, but one way to update the modification date is via Terminal using the "touch" command.
On your Mac, launch Terminal
At the prompt, enter in touch followed by a single space (don't press Return/Enter yet)
From the downloaded Firmware DMG file (mounts on your Mac's desktop as a volume named "eosr5-v181-mac", single click on the EOSR5181.FIR and drag it to the Terminal window. This should paste in the path (see attached image). Then, press Return or Enter. This will set the modification date to be the current date/time. It will not affect the contents of the file at all.
05-27-2023 12:20 PM
Yes, the 1.8.1 file is the only file on the freshly formatted CFExpress card. Like you, I don't think the modification date is the problem. I just found it a little interesting....
05-27-2023 12:29 PM
Changing to the SD card fixed the problem. Thank you so much.
Bill
