08-17-2025 01:33 PM
08-17-2025 01:55 PM
You might need the Canon AD-E1 hot shoe adapter. R series bodies have a similar, but different hot shoe design. I found an article about the strobe.
08-17-2025 05:08 PM
If you have the original EOS R5 not the EOS R5 Mk2, the Interfit should work.
Make sure that the shutter mode is set to mechanical or 1st curtain electronic modes. Flash will not be fired if the shutter mode is set to electronic.
Also make sure you have set a shutter speed of 1/125th or slower. if your Interfit triggers only has a central pin then you might need to set the exposure simulation to disable too.
