08-28-2020 05:05 PM
I received my R5 yesterday and took it out for a test today.
I have found that the Lens IS is always active even when im not pressing any buttons.
I would like the IS to only be activated when im pressing down the shutter button but i haven't yet found out how to do this with EF lenses. Does anyone know how?
With the Lens disconnected you get the IS settings tab in the menu (page 252 in the manual) and you can turn it to "only for shot" which makes it only activate once you press the button but as soon as you reattach the lens this setting tab disappears from the menu & still has IS always activated so that makes me believe this option doesnt work with EF lenses.
The lens IS only turns off when the camera goes into stand by mode, soon as you press any button to wake the camera up it activates the IS. Its not a huge issue but it means it will be draining the battery for no reason.
This is the only issue i have ATM with the R5.
11-29-2020 12:16 PM
I just recieved my R5 and I am having the same issue. Do you have any updated information?
11-29-2020 12:46 PM
@Peter wrote:
Same as with every mirrorless camera from Canon. M5 owner here with the same problem.
My M3 seems like it wants to do it, too, although I have used any IS enabled lenses with it. It makes noises with lenses without IS. IF you turn off Continuous AF, it stops.
People are certain that it is an IS issue, not AF. I would not know. If it stops when the camera goes idle, then I would not worry about it. The displays might consume more power than the lens motors. There's two of them.
11-29-2020 01:32 PM
Definitely a lens IS issue. If I have lens IS switched to ON the IS continuoulsy makes noise. As soon as I switch IS OFF it stops. Continuous AF is disabled.
11-29-2020 02:46 PM - edited 11-29-2020 02:47 PM
All my EF-IS lenses (using Canon EF-RF adapter) activate IS continuously anytime our two R5's are powered on. Obviously this is a battery suck so I'm forced to use a 30 or 15 second Auto Power Off setting - obviously Power Off kills all IS and saves power. FWIW, IS also shuts down when reviewing images or when IS is turned off at the lens.
Since EF lenses lack communication contacts and firmware for full IS coordination, maybe Canon decided the only or best way to combine IBIS with EF-IS was to leave the latter enabled always. That way IBIS (which effect is fairly minimal for EF-IS lenses) doesn't have to wait for the lens to activate, find and lock on to a subject and present a stablized image to the IBIS. IBIS can only respond to what the lens shows it. Unfortunately, this doesn't allow us to choose between IBIS and lens IS since any EF lens with OS disables the IBIS option in the R5 menu - the lens OS on-off switch controls all IS, it's either both or none.
There's a YouTube video from Canon that offers a good description of how IBIS is coordinated with OS. [https://www.youtube.com/watch?v=F7KuUgUqOfk&feature=emb_logo]
11-29-2020 03:01 PM
That's not the Rudy Winston video I once saw, but he describes only 3-axis IBIS control with EF mount lenses.
03-03-2022 12:50 AM
Ok I read and the problem with EF lens on r5 is the LCD while lcd active the camera is always focusing, if you set your LCD to turn off after 30 sec or off the IS will stop hunting 😉
