R100 won't record video with Rokinon EF mount cine lens attached to an adapter
markbolden
Am I missing something? On my T6i I had no problem recording video with my Rokinon cine lenses. I upgraded to the R100 and have a [pro]master EF-RF mount which works great with my Canon EF mount AF lenses (video and still shots). When I connect my Rokinon manual focus cine lenses and try to record video or even take a photo my camera does nothing. No shutter whatsoever.
Is there a menu setting I need to set for this to work?
Thanks in advance!
5 REPLIES 5
rs-eos
Note that if you're not using one of Canon's EF-to-RF adapter and using a third-party lens on top of that, it may very well lead to incompatibility issues.
If you get the chance, try a Canon adapter to see if there'd be any improvements.
Ricky
Agreed, but I did see a thread a day or so ago where the solution in the discussion was to enable shutter release w/o lens. I see YT tutorials on how to do this on other models, but I am having trouble finding this option on the R100. Any ideas on where I can find this in the R100 menu?
Yep, definitely a feature of EOS R100.  See page 593 of the User Manual.
Ricky
Thanks! I will give it a shot. Also, I just ordered the actual CANON adapter for future use. Cheers!
Waddizzle
The mount adapter is an issue unto itself.
Are able to capture stills?  When using a fully manual lens you must go into the menu and enable “release shutter without lens”.
