06-08-2013 10:41 PM - edited 06-08-2013 11:56 PM
Quick Control Wheel on my Canon 7D is not adjusting the aperture or shutter speed in M. Tried changing it to operate on the Main Control Dial and both aperture and shutter will work independantly when I make change, but the Quick Control Wheel will not control either. Any ideas?
06-08-2013 11:01 PM
Tripple check that the switch for the Quick Control wheel is ON. I had several instances where it was just a tiny bit out of the ON position with my 20D with similar issues. Flip it through the positions & back to ON & see if that cures the problem.
06-08-2013 11:01 PM
06-08-2013 11:59 PM
