01-27-2013 01:36 PM
I used my Canon T2i without problems for over a year and I am very pleased with it, but try taking days ago a video after have been taking pictures in program mode and the camera will lock and no picture could be taken, only appeared one minute later a pattern with vertical lines ... try removing the battery to see if it unlocked and nothing happened, every time I tried to take a photo red light indicates that the camera is processing, (acces lamp), remained continuously lit and not seen any photos. If anyone can help me solve this problem would be very grateful.
01-29-2013 05:02 PM
Hi Elepeley,
This may be an issue with the memory card. I recommend that you remove the batter and the memory card. Then replace the battery without the memory card and turn the camera on. If the camera function returns to normal except for the "No Memory Card" message, I'd try a different memory card. If the issue resumes or doesn't go away when the memory card is removed, unfortunately, your camera will require service. You may click this link for repairs.
03-16-2013 11:13 PM
09-24-2013 06:59 PM
Has anyone been able to resolve this issue? I am seeing the exact same behavior from the camera. If there is something we can do to fix this can you please share the solution?
Thanks!
Matt
11-18-2013 03:15 PM
Same problem. Camera function is normal until i take a picture, but if i do the camera freezes up, screem turns black, red light stays on and I am forced to remove the battery to power it off. My firmware is updated, I re-formatted the memory card, bought a new memory card, reset everything to factory settings and nothing seems to work.
11-19-2013 10:36 AM
whales,
At this point, given everything you have already done to attempt to resolve the issue, your EOS Rebel T2i will need to be examined and repaired by our Factory Service Center. To start your repair process, you'll need to complete a Repair Request on our website.
02-19-2014 05:56 PM - edited 02-19-2014 05:58 PM
forgive me my bad english
i have this problem and a canon service centre took a look at it. They informed me that is would be a mainboard error. It needs to be replaced. Would cost me 250 euro's.
I took the camera home to think about it. After a few weeks i tried again and....it works fine. I could take pictures again. But when i tried movie it freezes again with the typical distortion on the lcd. Needs to reset by taking out the battery. After a few weeks it got the error again with taking pictures. Nothing helps. Tried to put it away 2 weeks but that did not resolve the problem.
i tried everything. Firmware, ML, other sd card's, lenses, and then i saw this possible solution for an error 70. Not my error but you never know.
--power down camera and remove battery
--power down HDMI device or powered adapter
--unplug the HDMI from the body, then plug it back in
--power up HDMI device or powered adapter
--insert battery and power up camera
and gues what. It works perfectly. NOT the video function. It's still freezes. But taking pictures is working for months now.
Before it would give the error when i stressed the camera with continuesly shooting at sports or something. Then it became slower en suddenly it would stop and give error 80. And now i can do what i want. It keeps working.
It's worth i try?!
06-18-2014 11:23 PM
I hope this isn't way too late. I had the same problem and just successfully fixed it! I hope you have the same problem.
A part of my old SD card came off and stayed inside the card slot. It did 2 things.
1. prevent the spring action from catching the card. I would push in the card and it wouldn't catch. I had to close the door to keep the card in. It worked fine for about 2 weeks.
2. Until today. It would just give me a card error or no card in camera error or a bunch of other laments. I was very sad!
Then i peeked in with a flashlight and saw a few chunks of blue in the slot. I managed to pull them out with shaking, canned air and smacking. Lo and behold, all was well.
Photo of the pieces and a 67mm lens cap for scale.
