Photos not saved! 250d
Ninaxx
All the pictures I took in an afternoon have all disappeared from the sd card. Card wasn't full and I was able to playback images after they'd been taken but when I went to transfer them at the end of the day, they were gone! Any thoughts/ ideas/ advice on whether this has happened to anyone else and if images can be recovered?
Many thanks in advance
15 REPLIES 15
rs-eos
What brand of card are you using?  If it's SanDisk, you can try their recovery software.
Ricky
Ninaxx
Hey, thanks for the reply. Yes, it is ScanDisk. Can I use the recovery software with the sd card in the camera, or dhould I remove the sd card and insert into a card reader?
I would assume you'd need a card reader? As your computer would need to ultmately see it.  I've never used the software, so don't know.
Ricky
Ninaxx
Yes, I'm a bit in the dark too. Going to run recovery with sd card in reader and keep fingers crossed! Many thanks again for your help
is this a full size card or a micro card with adapter?
Ninaxx
It's a micro card in an adapter.
Can you still review the images in the camera using the blue playback button?
Ninaxx
So, when I took the images I could view in playback straight after and I could view pics throughout the day. But at the end of the day, I went to transfer pics onto my phone, I switched my camera on they'd all disappeared. No idea if it is the type of sd card that has caused this or what but ideally I need to find out how to avoid it happening again in the future
I don't know if this is your problem, but when folks report image loss problems on the forum microSD cards in adapters very frequently involved.
My suggestions would be:
1. Get a full size SD card for future use in your camera
2. Get a SD/micro/SD card reader for your computer and try and read the micro/SD card directly in the reader. Using the adapter introduces two additional sets of contacts that could cause a problem.
3. If still no luck try the image recovery software.
