Optimal Shutter speed?
Ryanjrector
Hi, I’m looking to buy a new camera. I currently have the Canon Rebel XT and I also have the Canon EOS 60D I am in the market for a new camera and I’ve been doing some research and I’ve found many cameras, but I have been wondering if the maximum shutter speed of 1/4000 of a second is too slow... I like to shoot a variety of different subjects and I would love to be able to stop the wings of a hummingbird using ISO 100 and a f-stop of 2.8. My question is, will 1/4000 of a second be able to do everything I want or should I go for a camera with 1/8000 sec possibilities?
I am looking forward to your feedback, Thank you and have a good day.
6 REPLIES 6
kvbarkley
VIP
VIP
Since we don't know *everything* you want, we can't say. 1/4000 is fast enough for most things.
For the hummingbird:
Assume that the wings beat at 100 beats per second or .01 sec/beat.
If the arc is about 6 inches, the wings move at 600 in/sec
in 1/4000 of a second the wings move about .15" , so it won't quite stop the motion.
However, at 1/8000 sec, it will still move about .07 in, so that is not quite stop motion either.
There is a reason Edgerton used a strobe.
TCampbell
Generally 1/4000 is fast enough to freeze almost any action.  Cameras that get to 1/8000 can let you do this with a shallower depth of field provided you have a low focal ratio lens (e.g. f/2 or faster).  (But there are other ways to solve that problem.)
e.g. suppose you are shooting in mid-day sun (not a great time to shoot, but we'll use the example).  The Sunny-16 rule says the exposure for f/16 would use the inverse of the ISO (assume ISO 100) as the shutter speed.   So that's 1/100th.
But suppose you want shallow DoF so you don't want to use 1/100th & f/16.
At f/11 it's 1/200
At f/8 it's 1/400
At f/5.6 it's 1/800
At f/4 it's 1/1600
At f/2.8 it's 1/3200 (and keep in mind that's the last "full" stop you can get with a camera that caps at a 1/4000 shutter speed)
At f/2 it's 1/6400
So a camera that can allow for a 1/8000 shutter speed could use the very shallow DoF you get with an f/2 focal ratio.
OR
You could just put a neutral density filter on the lens.  E.g. if you used a 2-stop ND filter you could shoot at f/1.4 (even shallower yet) at 1/3200
Tim Campbell
5D III, 5D IV, 60Da
Tim Campbell's response is right on as is Kvbarkley's. You will not be able to completely stop the hummingbird's wings even at 1/8000 on the 60D. However, if you shoot multiple shots in rapid fire mode and catch the wings at the top of the arc (or bottom of the arc) when they are reversing, you'll get the effect you want.
diverhank
The only time I ever used 1/8000 was to take a portrait picture outdoor at f/1.2...it was a bit too bright.  As a matter of fact I also used ISO 50 which is only available on the higher end Canon models.  You can also use an ND filter then you won't have to worry about not having 1/8000.
Diverhank's photos on Flickr
ebiggs1
"My question is, will 1/4000 of a second be able to do everything I want ..."
The truth and fact of the matter is, no camera will do everything you want.  There is no such thing just as there is no lens that will do everything you want.  That is one of the wonderful reasons modern DSLR are so adaptable and have interchangeable lenses.
ebiggs1
" I would love to be able to stop the wings of a hummingbird ..."
One of the reasons I don't rely on and don't only go by lab testing and school room math for photography is, it rarely tells the whole story of how well or poorly the results will be.  Can 1/4000 SS stop a hummingbirds wings?   Possibly.  One question that must be asked is, "How stopped do you want them?"  The math tells you little.  I have been shooting hummingbirds for years and I am going to show some shots, OK, not my best shots but take a look as none were shot at 1/8000 or 1/4000 or even 1/2000.  Well one was at 1/2000 !  Several conditions enter on how stopped the wings will be.  SS is onyl one of them.
Hummingbird chasing a Bee away from the feeder.
Yeah, they are not stopped absolutely still but none were shot at 1/4000 either.  Just keep in mind other factors besides super fast SS will enter into all your photography.  The best advise is get the best camera you can afford and go put it to use.
