11-24-2020 08:56 AM
Just recently bought a T7i and I used it to record a short video. The first video, I shot with a connected lapel wired lapel mic. The second take I did with just the camera's built in mic. When I loaded the video files on my Mac there is no sound at all in the videos. Either one. I assumed that the mic recording would be automatic. Am I missing something?
11-24-2020 09:38 AM - edited 11-24-2020 09:40 AM
The camera is not smart enough to automatically switch between an internal mic and an externally connected mic. It is probably a good thing that it doesn't, too. While the camera is in video mode, you need to go into the menu and check the audio settings.
If you do not know how to do that, then I suggest that you switch the camera to P mode, and reset the camera to factory defaults Once done, try to record video using the internal microphone.
11-24-2020 09:44 AM
11-24-2020 09:51 AM
With nothing connected to the camera, the built in mic should record sound when video is captured. Exception is miniture and Time-Lapse recordings.
See page 301 of your manual for details on sound settings and options.
eos-rebelt7i-800d-im-en.pdf (c-wss.com)
11-24-2020 10:22 AM
Do you hear sound when you play back in the camera?
11-24-2020 10:32 AM
