02-08-2015 03:02 PM
02-10-2015 09:59 AM
Like a basketball game? A flash will most likely get you thrown out of the gym. As it will with any indoor sport I know of.
If on the other hand you want a good general flash, get the 430 EX II but keep it out of the gym. It will work seemlessly with the Rebel T5i.
02-11-2015 09:11 AM
I am sorry but it is still not a good idea. With the T5i and what I am going to guess, you have the standard kit lens with it?
A better choice would be a faster lens. This is a lens with a small f-number like f2.8 or f2.
If I were you, and actually I am as I shoot hundreds of HS band concerts, I would save the flash money and look for a fast lens.
On the T5i a fast lens will do a great job.
02-11-2015 01:21 PM
@DCTWINKIEP wrote:
It will be used more for high school band concerts no sports. And thank you for the response.
There are exceptions; but in general, a flash bright enough to make a significant difference in a large hall is bright enough to distract the performers and/or the audience. It's one thing if you're the official event photographer and have coordinated your shooting with the producer or director, but otherwise you really shouldn't do it. Civilized photographers should not stoop to behaving like paparazzi.
02-10-2015 09:59 AM
02-10-2015 08:22 PM
02-11-2015 09:11 AM
02-11-2015 01:21 PM
02-16-2015 09:36 AM
02-16-2015 07:30 PM
@RobertTheFat wrote:
@DCTWINKIEP wrote:
It will be used more for high school band concerts no sports. And thank you for the response.There are exceptions; but in general, a flash bright enough to make a significant difference in a large hall is bright enough to distract the performers and/or the audience. It's one thing if you're the official event photographer and have coordinated your shooting with the producer or director, but otherwise you really shouldn't do it. Civilized photographers should not stoop to behaving like paparazzi.
On the flip side, if flash photography is not prohibited then you can expect a light show of flashes to be popping off the entire time. Most of them from cell phones far too weak to actually make any difference in the photo. Even if flashes are prohibited there's usually still an assortment of them.
It depends on the venue, but if flash photography is allowed then it'll be done, and having a flash (that is actually doing something) isn't going to be noticed any more than the rest. However, with a good flash and good telephoto you can get some great pics. You don't need to light the scene by flash, but splashing a little extra light can go a long way.
02-17-2015 09:18 AM
DCTWINKIEP,
Don't do it. Don't be that guy! This is not a good idea. Flash has it's place but not there. It seems there is always one!
02-17-2015 12:35 PM
While I highly recommend "owning" an external speedlite and learning to use it as an off-camera flash... don't use one at a concert.
Not just for the reasons others have mentioned here (the distractions), but also because frankly you wont need it.
Here are a few concert photos I've taken over the years... none of these used a flash.
The first image was taken with my original T1i. The image was shot at ISO 3200 (which would ordinarily be very high noise) but I've "de-noised" the image via Noiseware Pro (by a company called Imagenomic.) So this isn't straight-out-of-the-camera, but it is representative of what's possible. A T5i is, of course, a newer camera with better ISO performance.
This next image was shot with my 5D II... but at ISO 6400. This image technically does have noise (though you probably can't see it at this size.) If I inspect the shadowy areas, I do see a tiny bit -- but not enough to fuss over. I did not bother to de-noise this image.
This last image was taken with my 5D III. This was shot at ISO 3200 and basically has NO noise in it whatsoever. I post this because you can see I'm basically in a black room with a small amount of light on the performers (in this case Jon McLaughlin).
None of these used flash. You will NOT be shooting in less light than this last image (which I shot at ISO 3200.)
I am using an f/2.8 lens for most of these (which gathers 4x more light than an f/5.6 lens... in other words if I were shooting at f/5.6 then I'd need to use ISO 12,800 and that would be noisy.)
As a tip... when you meter these shots, the default "evaluative" metering mode will noice all the blackness, assume the shot needs more light, and will tend to try to over-expose the shot (because it can't believe the background is actually supposed to be black.) To get around this you'll either need to use spot metering and meter on the performers OR use exposure compensation (this last shot of Jon McLaughlin was shot with exposure compensation set to -1.3 stops because a netural exposure compensation would have over-exposed his face considerably.)
1) Don't use flash
2) DO use good glass. I'm using a Canon EF 70-200mm f/2.8L IS USM. I also use my EF 135mm f/2L USM for concerts (though I don't think any of these shots happened to have been taken with that particular lens.)
02-17-2015 04:23 PM - edited 02-17-2015 04:31 PM
Ahh. Ok, I recant my statement. I assumed gym band meant more like a marching band, before/during a game, pep rally, etc. With everyone up in bleachers. Yes, if it's that kind of band/setting with lighting, then obviously don't use flash. But you're really going to benefit from moderately fast glass.
However, I don't think I'd say that's the darkest setting you're ever going to shoot in. The stage lights are actually really **bleep** bright... and hot.
