02-04-2019 10:27 PM
I am new to real estate photos and most of the trianing I am watching and reading is telling me to use the followiing settings to start with in a room
ISO 320, 1/125 at f8.
My T6i cant do ISO 320! 😞
Should I use ISO 200 or ISO 400, next question for be what would the 1/125 need to be change to to have the same
02-04-2019 10:53 PM - edited 02-04-2019 11:01 PM
I would bump it up to ISO 400. There really isn’t much difference.
You can keep everything else the same as the ETTL Auto flash will be supplying the light to match your camera’s 1/125 and f/8 Manual settings.
Do you have an ETTL flash?
02-04-2019 10:55 PM
Yea but I was doing it in manual mode
@MikeSowsun wrote:I would bump it up to ISO 400. There really isn’t much difference.
You can keep everything else the same as the ETTL flash will be supplying the light to match your 1/125 and f/8 Manual settings.
Dou you have an ETTL flash?
02-04-2019 10:59 PM
Did your “training” tell you to use Manual flash?
You can use the flash in Manual mode but it just means more work. Unless you have a flash meter, you will need to experiment with different flash power settings to match the light needed for each shot.
02-04-2019 11:36 PM
@johnathansmith6 wrote:I am new to real estate photos and most of the trianing I am watching and reading is telling me to use the followiing settings to start with in a room
Did they also point out that you really do not need a flash for most real estate photos?
Most real estate photos are static scenes, where nothing is moving. All you really need for real estate photography is a tripod. Shoot using Av mode, with a stopped down aperture and ISO set to 100.
02-05-2019 12:53 PM
Scott Hargis is apparently one of the most respected real estate photographers in the US. I suggest you do a search for his name and look at his publications and videos. They are worth the effort - in the PDF book I have he takes you through lighting each kind of room
Similary if you have access to Lynda.com, which is an excellent tutorial service with videos covering almost every topic you can imagine, there is a series of excellent videos in the real estate section, again covering every room scenario.
02-06-2019 02:54 AM
"... you really do not need a flash for most real estate photos? "
Avoid using flash. It will only complicate your shots and they will look awful.
02-06-2019 10:38 AM
thanks. I got the book
