04-15-2014 10:15 PM
Hi, my first post here. I just got a new T5i this past weekend and I'm having trouble with the SD Card. It is loading pictures in to my computer photo library in correct order of the picture being taken. I will have picture number 0ne when actually it was like the 5th pic I took. Pic 2 might actually be like the 10th pic I took.........nothing is in correct order. Thanks for your help.
04-17-2014 10:32 AM
04-16-2014 09:01 AM
04-16-2014 09:09 AM
I have a Dell with Windows 7, I am putting the card directly into the SD Card slot of the computer. I am loading them to the file "My Pictures" the same way I have done for my other older Canon Camera
04-16-2014 10:04 AM - edited 04-16-2014 10:04 AM
Are you saying the file numbers that the camera (T5i) puts on the photos is not in order? I doubt that is even possibile.
Try inserting the SD card in to the computer and use Explorer to check the file numbers. Do not transfer them just look.
If they are in sequiential order, than your software is doing something......strange.
04-16-2014 02:57 PM
I took a series of shots of 5 different items, 4 pictures of each item. Down loaded in my computer and they are all mixed up again. I took the same SD Card and put it in my old Canon and took eight pics of paper numbered 1-8. Down loaded in my computer and they were in perfect numeric order. It has to be something with the new Canon.
04-16-2014 06:39 PM
04-17-2014 10:22 AM
Of course the SD card needs to be formated in the camera it is to be used in. Never any other way!
But I believe this is a software problem and not a camera one. Your software is messing them up.
04-17-2014 10:32 AM
Problem was resolved, it was a software issue. Thanks for the help.
