07-21-2013 09:46 PM
Recently bought new memory card for faster writng for wildlife photography. Card sometimes writes slowly and sometimes locks up camera. A while back I got a notice for firmware update on 7D, but was having problems with internet connection and never did it. If this is the problem, where can I find the link on the Canon website? Or is this a different issue?
07-21-2013 11:17 PM
The latest firmware for a 7D is v2.0.3. You can find it here: http://www.usa.canon.com/cusa/consumer/products/cameras/slr_cameras/eos_7d#DriversAndSoftware
You can find Canon's comparison of performance here: http://www.usa.canon.com/cusa/consumer/standard_display/EOS7D_firmware_compare
I normally only shoot RAW... but if you're needing continuous burst speed with a large number of frames, the number of shots you can get in JPEG is considerably more than you can get with RAW before the camera buffer fills and the frame-rate drops.
07-22-2013 12:32 AM - edited 07-22-2013 12:35 AM
07-22-2013 07:23 AM
07-22-2013 07:26 AM
Sorry, it 's a Lexar Professional 1000X and I bought it from B&H. The problem occurred in single shooting in JPEG or RAW.
07-24-2013 07:53 AM
Hi Ed-7!
What version of the firmware do you have on your EOS 7D?
If it is not up to date, I recommend doing so. Per what TCampbell wrote above, the latest firmware for a 7D is v2.0.3. You can find it here: http://www.usa.canon.com/cusa/consumer/products/cameras/slr_cameras/eos_7d#DriversAndSoftware.
07-24-2013 07:26 PM
Thanks for the imput. I contacted Lexar support and they said try a different memory card and if it works, return the questionable card for exchange. I'll try that, but I will update the firmware at my 1st opportunity.
